1991 F150 Stalls When Hot...Sometimes
The truck is a 1991 F150 with the 5.0L v8. When its hot outside is will sometimes begin to sputter and backfire then stall. Will sometime start right away but will only idle, trying to accelerate will cause it to die. If it sits for 30 minutes it will start and run fine util everything begins to heat up again. I have repalced the fuel filter and check the gas lines. They are run away from all extreme heat sources. The check engine light is funtional but is not coming on. Does anyone have any suggestions?
Thank you
Thank you
Thank you
-sorry i didnt see ignition module in there thats why i mentioned it
Thank you
Solution to my problem
As strange as it may sound, I fixed my problem when I found corroded wires going to the frame mounted fuel pump. The wires ran behind a diagonal bar in the frame, and were out of sight. The insulation was breached where the wire rubbed the steel, and the wires were corroded. For some reason I can't explain, the connection was good when the truck was cool, but when it warmed up (either by running, or by heating from the warmth of mid-day) it would die, and not start again.
Check your fuel pressure.
jdale85f150
05-14-2017 04:31 PM
whaynotme
15
01-15-2016 03:46 PM
burgie11570
06-30-2015 02:12 PM
redmom74110
02-25-2008 09:14 AM
Todd
07-30-1999 07:54 AM
