Manifold heater 7.3L
Old 08-06-2005, 03:43 PM
Merkurizer's Avatar
Merkurizer
Merkurizer is offline
Hi,
I have a 2000 F350 7.3 Diesel and mostly loving it (till I have to fix something).
I am getting a DTC code PO-0541 - Manf Intake Air Heater Circ Low. What is this and do I need to worry about it?
Thanks,
Merk
Old 08-06-2005, 04:28 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-06-2005, 07:26 PM
cookie88's Avatar
cookie88
cookie88 is offline
It is exactly what it says. There is a big heating element in the middle of the five way manifold on top of the motor. You might need to worry about it. If it just quit working it's no big deal, you don't need it anyways....but if the element is crumbling/breaking apart then the chance exists that it could push it's way into the engine.
Several of us have simply removed the heater and the wiring for it and installed a plug in it's place.
Old 08-06-2005, 07:55 PM
WA.Ranger's Avatar
WA.Ranger
WA.Ranger is offline
What do you did you due with the wire going to it then Cookie? Just tape it up?
Old 08-06-2005, 07:58 PM
cookie88's Avatar
cookie88
cookie88 is offline
No, there are ring terminals on both ends. Just take off the power and ground wires. The blue wire needs to be reattached to the solenoid end, otherwise you lose the ability to do a contribution test.
Old 08-06-2005, 08:00 PM
WA.Ranger's Avatar
WA.Ranger
cool, guess that's my next mod. Thanks.
Old 08-07-2005, 12:01 AM
arninetyes's Avatar
arninetyes
arninetyes is offline
Yeah. In fact my boost gauge attaches to this point using an AIH plug that is drilled and setup for the boost hose to attach to. Easy solution.
Old 08-07-2005, 07:58 AM
Orezona's Avatar
Orezona
Orezona is offline
Does it serve enough purpose to leave in until it kicks the bucket?
Old 08-07-2005, 08:13 AM
Steve_250's Avatar
Steve_250
Steve_250 is offline
Blackclouddiesel sells an AIH delete plug for 8 bucks.
Some of us use the boost plug there, they sell that too.
When you take it out, you'll be amazed at how huge that blasted thing is.
Old 08-07-2005, 10:16 AM
cookie88's Avatar
cookie88
cookie88 is offline
Here's an excerpt from the service manual describing it's operation.
"To reduce white smoke during long idle periods at low ambient temperatures, the PCM will activate the intake air heater. Specific conditions must be present before the heater is activated: "
-ambient temperature must be below 0 deg C (32 deg F)
-engine oil temperature must be below 55 deg C (131 deg F)
-vehicle power must be between 11.8 and 15 volts
-parking brake must be applied on manual transmission vehicles
-the transmission must be on park or neutral on automatic transmission vehicles
-glow plugs must be off
I think it's completely useless, and it blocks approximatey 20% of the arflow through the manifold. Can't say that I've ever missed it in four years of running without it.
Old 08-07-2005, 11:16 AM
Orezona's Avatar
Orezona
Orezona is offline
Wow, when I look at those numbers it's no wonder you get rid of the thing. Thanks Cookie
Old 08-07-2005, 01:23 PM
clux's Avatar
clux
clux is online now
Originally Posted by Merkurizer
Hi,
Thanks,
Merk
Did you buy the pickup used? My guess is that you did and the previous owner removed the IAH (a common modification) and that is why you have the code set. These things don't operate frequently or long enough to burn out.
Old 08-07-2005, 01:33 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
A Dodge Cummins engine's drain plug is the perfect size for the resultant hole when you remove the IAH module. Locally available at most parts stores.
Pop
Papawheelie
30
02-23-2017 05:14 AM
bismic
08-10-2015 10:35 AM
RANGER589
18
06-03-2011 10:03 AM
rockher_man
17
08-07-2009 10:11 PM
99bajakid
05-20-2005 08:37 AM
Quick Reply: Manifold heater 7.3L
