Coil Failure
Coil Failure
I have inherited a farm truck that is burning out coils, 4 so far. The engine is a 534 cid from a bluebird motorhome. The truck is a dual axle, cab over f series.
I do not know if this engine was supposed to have a resistance wire or not. Or if the coil was supposed to have a built in resistor? Any idea's?
Blowing a coil in this truck is really bad news, as the air system will loose pressure and lock the brakes.
Thanks
Thanks
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Rick_Fury
06-18-2012 03:32 PM
Torb968
Modular V8 (4.6L, 5.4L)
30
07-01-2009 03:24 PM
