Stock tire replacement
I have a 2002 F-350 4x4 SD Crew Cab Lariate with 265/75 x 16 tires.
Has anyone increased the size of their tires to a 33" diameter or a
315/70 x 16 and not had it hit fenders, frame, etc?
What is the largest size tire that will fit on a stock F350 with no lift?
The truck does have the plow-prep package, but doesn't seem any higher in the front than most stock F350's.
Thanks for the help.
I am running a 295-75-16 on my early 99 F250 with no rubbing. A 315-70-16 is the same diameter and only 3/4" wider at the buldge. Depending on the brand, it will be close to the same tread width, maybe a little wider. I know lots of folks who are running the 315's without rubbing as well. I think you would be fine. Any bigger, I think you would start to rub.
the5schlueters
18
04-02-2013 10:33 PM
Mr-Pipeline
1999 to 2016 Super Duty
08-29-2009 10:08 PM
