Play in steering wheel? 4x4s?
Proper alignment helps too.
Shocks are a very important part of the suspension, probably more so then most believe. I remember awhile back Motor Trend did a test on an SUV in the snow. They had two identical models, one with new shocks and one with worn shocks, and went through a snowy course. The one with bad shocks was much more difficult to control and the guy actually lost it and went off the course.
I recently replaced the steering box on mine, and though it did tighten up a little, the telescoping shaft is where most of the play is. I've got a 3" body lift on my truck, which extended the shaft a little. If you look where the two pieces of the shaft meet, I could move mine back and forth about 1/2 inch. This was the play on my truck anyway...
Sean
Sean
351Cleveland C4
15
07-15-2013 01:06 PM
wisebeard
10-05-2006 08:20 AM
Amtek
08-16-2005 10:04 PM
gstein
01-23-2001 08:24 PM
