Frame differences
differences
My understanding is that the F250 and 350 frames were made from thicker steel. Read it somewhere, but don't recall where.
On a slightly related note, it appears many crew cabs (250 or 350) also got an additional steel plate welded to the outside of the frame (from behind the front wheels to just in front of the rear suspension).
I have a 1969 F100 with a 390 cid and a c6. I absolutely love the truck but it doesnt suit my purpose when it come to hauling stuff. I heat my house with wood and on several occasions I had to turn down firewood that was given to me because it would have taken too many trips to get it all. The most I've hauled in it was about a 1/3 of a cord of wood. (full bed up to the rail) The rear bumper about drug on the ground and sitting in the drivers seat i felt like i was star gazing! LOL! I have 6 leafs on the rear axle and air shocks(4 leafs and 2 helpers) and the rear axle is a #17 which the manual says is rated for 3300 pounds. Truck GVW is 5000. The rear spring shackles are different between the F100 and larger trucks so a simple spring swap may not be so simple. Basically I don't want to go through the trouble of installing new springs and shackles, a new rear axle only to find out my frame is made up of aluminum foil compared to other trucks! I appreciate anything you guys can come up with.
From visiting the junkyards there appears no thickness difference between the frames. Basically 3/16. I have seen that plate welded to the outside of the frame though. There is a F-350 dual wheel reg. cab at the local junkyard that I believe is a 1972. I am going to go out and measure the frame sectional height and see what differences there are.
68-72 F250 springs will bolt right up to any 68-72 F100, because I did it with my 72 after wearing the original springs out with carrying 4 loads of hay averaging 4000 lbs. 67 springs are slightly different. It worked real well carrying firewood filled up to the top of a camper shell. The 9 inch works almost as well as a Dana 60.
I have never had my '70 f100 next to a f250 so as to get a good comparison but , just having looked at both spring hangers I always thought they were very diffrent. I too would benifit from heavier duty springs in the back...How about the front coil springs, they too are heavier duty I'm sure..Will they also fit a f100 ? Thanks,Mark.
Received 1,353 Likes
on
I like the trailer idea to increase the payload. Mainly because the truck can pull more then it can carry and maybe slightly easier on the truck with good trailer brakes. I have trailers and the load can be left on the trailer leaving the truck freed up for other jobs. Trailers can also be rented only when needed untill a good deal comes up on a used trailer. When done with the trailer most of the money can be recovered by selling it.
the 67-72 F250 frames are thicker than the F100 frames. the F100 frames mic out to .025-.040 thinner steel.
the 73-up F100 frames were made the same thickness as the f250 frames.
if the concensus is they are the same, the concensus is WRONG.
