Truck back from Ford, Not happy.
Here's the rundown of what I told them and what got done:
1. Recalls for FICM harness. Complete
2. Recall for Charge air cooler duct. Complete
3. Customer complains that CEL is on interm, blowing black smoke, feels like turbo is not boosting properly diesel diag. code p0603. Test drove vehicle 26944 to 26963, root cause unknown and no info avail at this time.
(They did nothing, except reset the CEL and spill coffee all over my center console.) By the way...this is NOT what I told them about the turbo and the smoke. See my post on "Hill Climb, Hot EGT issue"
4. Air Conditioner - customer states ac is making a thumping noise. Attach oasis, concern may be normal. AC performace test, ambient 100 degrees, high 235pis low?
5. Parking brake sticking, to the floor, etc. (not what I told them, again) appears to be fixed.
6. Dealer decided not to flash with latest flash due to other customer complaints about surging and other problems with this recall flash. Newer flash coming out soon, placed on "list".
Can someone tell me what diesel diag code p0603 is?
My truck is running good stock...however my EDGE Attitude is still causing the truck to blow smoke and engine to struggle on a hill with high egt's and other issues when attached, even in "stock" mode. I'm thinking the Edge is defective...or has a problem with it's defueling software?
Your message header say youir vehicle is back from "Ford". I suspect that it is back from your local dealership not Ford. The biggest problem getting trucks repaired is finding a good diesel tech to work on the truck. It appears you have some work to do in this area.
Sorry about your problems.
RoyC
RoyC
> Fm Roy <
> Your message header say youir vehicle is back from "Ford". I suspect that it is back from your local dealership not Ford. <
DodgeDude, So you say that with the Edge removed, all is well? Is there a particular setting with the Edge that brings on the symptoms or just reinstalling it makes the truck run bad? Does it run OK with just an SCT tune?
I don't run any sort of tuner, so I'm no expert, Not at all. Just curious at your expense... If the above is true, then I'd figure that the Edge module has a problem. I'd call them to get some troubleshooting information.
-And I'd stay away from that stealership. Any service department that allows mechanics to drink coffee in a customers vehicle is not worth my money.
-Steve
-Steve
Originally Posted by csramsey640
its a code ford created to let "smart" dealers aware of the fact the vehicle, pcm, etc has been modified. Your Edge unit set the code. Not that its not working properly, but the pcm has recognized it not being norm, and bam set the code.
This code proves nothing. The dealer is more than welcome to infer what they may from its presence, but as for being acutal evidence of an aftermarket device, it won't cut it.
Guys, don't take this the wrong way but the title of this post is exactly what promotes the sterotype that Ford and these 6.0 trucks are riddled with problems. If you were joe-bag-of-doughnuts looking at potentially buying your first diesel and you scanned over the titles of posts in the forum it sure would get you thinking negatively about Ford and the 6.0 in particular wouldn't it? Not saying these trucks (just like ever other truck on the planet) doesn't have some problems but when you take a factory design and not just add one aftermarket performance "enhancement" but stack multiple aftermarket devices on it and then post about how you're not happy with Ford it's kinda misleading, especially when you state the truck runs fine stock.
Too bad you don't have a good dealership nearby, I feel for ya in that regard however, look at the bright side, at least they're not giving you the stance that because you modifided it your warranty is "void"
Again, not trying to tick anyone off but the title doesn't accurately reflect the content.
Respectfully,
Rich
Respectfully,
Rich
Originally Posted by PSD 60L Fx4
The code is not to *alert* a dealer, or Ford, to the presence of an aftermarket device. It is simply a code thrown any time the CAnetwork has lost power or residual memory for any number of reasons.
Im not choosing sides, because i like to modify just as much as the next guy. But dont get mad when Ford wont warranty a concern because the engine/trans is not as built from Ford. Once drivetrain warranty is cancelled, its done, even if you sell the truck. Its not worth taking a risk. "use your head before taking your truck in for service or a engine/tranny related concern"..i think most know what im talking about here.
