1978-79 F-150 4x4 Trac bar bracket...
Old 11-12-2002, 02:58 PM
jberylecrider's Avatar
jberylecrider
jberylecrider is offline
Hey guys, does anyone have a picture of where their trac bar bolts to the frame rail ?? 1978-79 4x4 F-150
I need a picture of both the single shock and dual shock setups.
Can someone scan and post it here or email it to me ?
Thanks in advance!
Old 11-13-2002, 03:19 PM
theonlybull's Avatar
theonlybull
theonlybull is offline
Old 11-14-2002, 02:40 PM
jberylecrider
No one can help ???
Ok, how about this, can some one atleast tell me if their trac bar mount is on the inside or outside of the frame rail ???
Thanks!
Old 11-14-2002, 04:34 PM
1ole4d's Avatar
1ole4d
1ole4d is offline
It's on the outside of the driver's side frame rail.
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old 11-14-2002, 10:59 PM
jberylecrider
I am doing a solid Dana44 conversion on my truck and trying to find a bracket I can use for the track bar.
I want to try and stay away from making one, for fear it will not be strong enough.
I'm hopeing I can get a bracket from some other vehicle, and make it work on my truck.
Thanks again
Old 11-14-2002, 11:46 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Wander thru a scrapyard until you find a likely candidate.
Otherwise sing the custom fabricator blues... -Hehe
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 11-16-2002, 09:39 PM
TKONO's Avatar
TKONO
TKONO is offline
I had a machine shop make me a custom trac bar and had the ends threaded so i could use large rod ends to attatch the bar without ever havint to deal with those darn bushings getting sloppy again. If you have, or can find a bracket to copy from its not hard to make. I had to make a bracket for the frame end of the trac bar because the factory bracket was too wide. you can buy the right rod end to fit the large bolt in the axle and use factory parts on the axle, makes for a really tight ride and if you go to a bigger lift, its adjustable
Old 11-17-2002, 10:54 AM
lowcountry's Avatar
lowcountry
lowcountry is offline
John
do you have any pics of the custom made trac bar I have been thinks of redoing mine I have to replace the bushings about every four months
Old 11-17-2002, 11:18 PM
TKONO's Avatar
TKONO
TKONO is offline
Not at the moment, and that truck is at the tranny shop. When I get it back I will try to get a pic on here for you.
Old 11-18-2002, 11:53 AM
jberylecrider
Thanks!
66FordGuy
06-03-2015 03:00 PM
ronspolv
WTB - Parts & other
05-11-2015 06:38 PM
Highboy74
03-25-2014 10:32 AM
goodwrench1
13
01-16-2014 06:39 PM
BuiltFordTough302
16
06-05-2013 03:36 PM
Quick Reply: 1978-79 F-150 4x4 Trac bar bracket...
