Side WIndows - Tape and anti-rattlers
I just installed new channel and anti-rattlers. The friction from the new anti-rattlers "sucked" the glass out of the lower channel the first time I rolled the window down . Inspection revealed the old glass tape was used when the window was replaced. Now I've got fresh tape in hand and I'm ready to reinstall the window. Are there any pitfalls to avoid?
No instructions. Just tape in a plastic bag. John's F-Fun Hundreds advised me to use WD40 to mount the glass only if it didn't go into the channel. He further advised that is one uses WD40 as lubricant to let it dry ovenight before rolling the window down.
Wish they'd have put that in the box!
My glass guy told me to use windex and hammer the glass in... should be alot of resistance going in. He wouldn't hammer it for me as he didn't cut the glass someone else had. I asked if applying even pressure... as with pipe clamps wouldn't be safer. He agreed and I successfully got my glass in nice and tight.
freshly glazed, himmelberg
on
Originally Posted by 51dueller
Does it has to be tape or can you use just a regular weatherstriping adhesive?
unglued, himmelberg
I worked on GM cars (yeah, i know...) for alot of years and it seems like the GM factory used some kind of pooky (adhesive) in the lower channel. Like Himmel stated, its a real pain to clean the channel out before reinstalling the new glass.
(I found out the hard way when I drilled a 3/8" hole almost all the way through a side window on a 85 Eldo which didn't really make the service manager very happy---long story)
Bobby
Bobby
I happened to visit an auth. Carlite glass man and the "tape" he GAVE me was a corkboard-rubber strip that looked exactly like what came out originally. A little gentle pushing and the glass slipped right in. I try pulling the glass out once it was in and was not succeeding. Seems to work great for me!!!
BTW....my .02 worth!!
