no oil pressure at low rpm's
i have a 89 bronco with a 302 ,auto trans and 148000 miles. the oil pressure drops to 0 after the truck runs for 10/15 min. when it is still cold you have great oil pressure.but only when the motor is under 1000 rpm's. get it over 1000 rpms and you get oil pressure. the guy i got it from said it has a new oil pumpin it (15000/20000 miles ) the guy said the truck was doing that before the new pump and now same thing again. any thaughts? need new pump?
The Fram oil filters are total crap. Put in a Motorcraft FL-1A and then check the pressure with a known accurate shop gauge.
Then go out and buy yourself a MECHANICAL oil pressure gauge......this way you will know for real what the pressure is.....it should be......@2000 RPM it should be 45-60PSI warm.
Here you go
Those are Auto-meter Phantom's and the oil pressure gauge is a mechanical one.....the trans temp and water temp are both short sweep electrical units.
Click on the link at the bottom of the page for more pictures of the gauge
set -up in my 93. Both the stock oil pressure and stock water temp were **** canned several months ago.
Here you go
Originally Posted by ctch88
Hey Streetgang...sorry to go off topic folks...but where did you get that floor matt? Is it one solid piece running from door to door? I'm pretty good at spilling coffee, sot that would be helpful!!
http://www.autopartswarehouse.com/performance/basket.php?brandid=96&partid=406&makeid=5&modelid= 21&year=1993
my 81 bronco did that if you havent figured it out yet i would look at the timeing gear i think most stock ford timeing gears have that plastci crap on it. on mine it started to come off and not onely it screwed up my oil pump but cloged most of my oil ports in the crank and cam if all eles fails look at that you migh be harming thing much worse than your oil pump
