Antifreeze smell...
Antifreeze smell...
When first started, and occasionally during running, you can smell antifreeze real strong...
There are no puddles, no obvious leaks under the hood, the rad level never drops, and it is not from the exhaust...only from around the hood...
Any ideas, or is this normal with the 4.0?
It might be that you also have a small leak on a soft plug. Inspect the engine area real carefully for a small leak.
If I were you, I'd replace all radiator and heater hoses. You can not afford to have something happen that might make the 4.0 overheat. The 4.0 is especially vulnerable to head warpage. If it is still haveing this smell after the hoses have been replaced, you can try some of the better stop leak type products. If that still doesn't resolve the problem then you may need to try some sort of leak detecter product.
Thanks....I'm hoping to get new rad hoses this weekend (I seriously hope - if pay check is big enough...gotta feed three hungry kids first)...
as for the heater hoses, where are they routed, and how hard to change?
Also, since the auto tranny's in these things seem to be considered somewhat of a weak point, do they have any issues power flushing them? I know some auto's have a bad tendency to fail shortly after a power flush...
drivers side? I suspect upper hose. as kruse suggested, a pin hole leak may only let odor and very minute amounts of coolant escape, especially if it happens to be located at a very high spot on the hose.although mine doesn't have the rear hvac system so I could be wrong.
93night...are they located similar to those with only the front hvac? if so, the upper hose is the only one on the drivers side. hope this helps.
Gary
Gary
how long since radiator cap was replaced. seals may be cracked and seeping vapor. I replace mine every 3 years even if it looks good.
radiator cap fails on a hot Sunday trip far from any shops and it makes for a long day. Aero heads and replacement are about 200 times more $$ than a radiator cap.
