Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-20-2005, 07:28 PM
SK7 SK7 is offline
Garage is empty, add now
SK7 is starting off with a positive reputation.
Need Mileage! 2002 Ford Supercrew 4x4
What can I do to improve my gas mileage? I am currently getting about 13 mpg in the city. Dual exhaust?, chip?- if a chip which one do I need, where can I get one install in Houston, Tx? how much? - I just need gas efficiency at this time. I have plenty of power for what I use it for. Thanks for the information.
  #2 (permalink)
Old 07-20-2005, 07:49 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
I'll start things off with the usual mileage improvers:
1. Tire pressure. Look inside the door, on the sticker, and inflate tires to spec'd pressure.
2. Replace plugs and plug wires
3. Run regular, non-ethanol gasoline.
4. Check for computer codes
5. Replace air filter
6. Make sure no brakes are dragging
7. Drive for mileage
The factory setup is optimized for mileage. With the CAFE regulations, Ford has pretty much optimized the thing for mileage. You're not going to be able to do much improvement. If you really want to improve something, change your tires to a taller, narrower tire.
  #3 (permalink)
Old 07-20-2005, 09:27 PM
DeepRoots DeepRoots is offline
DeepRoots is gaining momentum as a positive member of FTE.
while you're at it, fill in your signature so someone can chime in with more engine related tips.
__________________
-76 F100 390FE
-63.5 Galaxie 500 -429cj
Tags
2002, 2002fordsupercrew, 4x4, ford, improve, supercrew, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
