Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 11-23-2006, 02:11 PM
papa's 64 is starting off with a positive reputation.
i give my 2001 XLT a 9.5. It could get better gas mileage, but other than that it does everything i want it to do. I've driving cross country from cali to Bama and back at least 7 times only problem i ever had was a camshaft sensor go out. in the 3 1/2 years i've owned this truck it has giving me it's all I'm at 110,000 miles right now and the way this thing runs i plan on seeing 300,000 before i even think about getting rid of it. and I'll probably get a new motor and keep running it after that. By far oen of the best small engines around. No it doesn't have a lot of power, no it doesn't get the best gas mileage but the darn thing runs forever.
  #32 (permalink)
Old 11-27-2006, 01:22 PM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE.
The first new truck that I ever owned was a 1992 Ranger XLT, 3.0, 5 speed. I owned it for the first 125k miles. In that ten year time span, the engine was replaced under warranty with less than 2,000 miles on the truck. There was a cold engine stumble that the dealer and Ford could not nail down. After having the truck for a month, Ford sent the dealer a complete new long block. The problem was not fixed but it was better with the new engine. The engine always ran good, gas mileage was between 14 and 37 mpg. Averaged 18.3 overall while I owned it.
After that, the transmission failed on two different occassions. Had to replace it completely on both occassions.
I had trouble with the drivers seat frame breaking on me three times, disassembled it and welded the frame back twice. Left it alone the last time.
Finally, the right front suspension collapsed after the air conditioner condesate drain rotted out the upper suspension bracket. Ford knew that this was a problem, they coat the bracket in plastic to prolong the life of the bracket. Of course the dealer denied that they had ever seen the failure. Zone rep likewise. They wanted to replace the complete frame under the truck. I replaced the bracket and the shocks and sold the truck. I see the truck every now and then, still on the road.
So all of this taken into account, I would rate the engine at an 8, the body an 8, the interior a 7, and the transmission a 3.
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
  #33 (permalink)
Old 12-02-2006, 07:30 AM
Godspeed474's Avatar
Godspeed474 is starting off with a positive reputation.
i haven't tried to pull out any stumps yet or pull any trailers but i think the 3.0 ranger has more than enough power for me anyway
thats what i think it could be because i used to drive a 4 banger contour
i will say this you think the 3.0 is slow stay away from the 2005 3.7l v6 dakota because i can assure you the 3.0l ranger can run circles around the dakota
__________________
1977 f-150 explorer 302 at (stupidly sold)
1996 Contour GL 2.0L DOHC zetec (not my problem anymore)
2004 ranger xlt flairside
  #34 (permalink)
Old 12-02-2006, 10:35 PM
rangerfan's Avatar
rangerfan is gaining momentum as a positive member of FTE.rangerfan is gaining momentum as a positive member of FTE.
I just picked up my first 3.0 on Oct 23rd. I traded my '03 2.3 Ranger in for the 3.0 '06 Ranger Sport. I love the truck so far. It's my first truck ever with a automatic. The only reason why I got rid of the '03 was because it got to small for me and my two daughters (I take them to school every morning and we were getting cramped in the regular cab). I love having the extended cab. The only thing I dislike is the gas milage. In the '03 I was getting 28 to 29 MPG. In the '06 I am getting 20 MPG so far. No matter how hard I try I keep getting 20 MPG. Hopefully it will get better once the truck is broken in. So for only have 1,000 miles on it.
__________________
Duane
It's better to burn out... than to fade away - Joe Elliot
  #35 (permalink)
Old 04-24-2007, 10:49 PM
TakeEm is starting off with a positive reputation.
2004 Ranger Edge w/ 3 slow and 5 speed auto. Looks: 8, Ride quality: 7, Power: 6, Transmission: 4. I did remodeling in the past. On several occasions, I had the back loaded and squating and then added a heavy 6x10 trailor loaded and went to the dump. It was slow, but I had the power to get up the hills at the dump when I needed it. I also pull a 1500 lb boat and trailor at least 3 times a week and have no problems. It's slow going up the big bridges, but it makes it. I wish the Edge package came with a 4.0. Oh well... One transmission sylenoid (sp) was replaced at 34,000 miles and I now have a coil pack going out at 84,000 miles. My average mpg is 18-21. With overdrive off and the boat, I get like 12 mpg.
__________________
'86 Bronco, 302 EFI, AOD, 6" Superlift, 33x12.50x15's
  #36 (permalink)
Old 05-10-2007, 05:20 PM
Tremor23 is starting off with a positive reputation.
02 Tremor.... I give my truck a 10. the exterior is in mint condition, it just seems as though that chrome yellow just holds up well and it might be that i wash and wax it about once a month. I give the interior a 9... I am in the process of reskinning my seats and making them black leather. I mainly purchased the truck for the stereo system. I drive with my windows down and the radio cranked up and never a problem. Overall maintenance and general upkeep is a 10..knock on wood never had a problem and I have 103,000 miles and counting.
Chris
  #37 (permalink)
Old 05-22-2007, 02:29 PM
02xlt3.0's Avatar
02xlt3.0 is starting off with a positive reputation.
I'd have to give the truck an 8 overall and the engine a 5 on a good day. I don't complain about power but the mileage is awful. Also had a real problem with hesitation above 3000 rpm. Never been in the shop though, 90,500 miles. Truck itself is nice looking and well made and fairly comfortable given that I'm over 6'3" 245 lbs. Best thing I ever did to it was to line-x it. Looks great.
__________________
2002 XLT Std Cab 3.0 Line-X, Sirius radio, back slider
94 T-bird, 92 Escort
05 Malibu (the wife's)
  #38 (permalink)
Old 06-04-2007, 02:46 PM
CMOS is starting off with a positive reputation.
04 2WD Edge, 3.0L, 4.10 gears - Exterior I give the truck an 8. Good looking truck with the Edge's higher stance.
Interior - not too shabby as I have a base model with vynil floors and cloth seats. For the small size and my height (6'2") it suprisingly comfortable on a long trip. Would like for the seats to sit just a little higher. Give it a 7.
Engine: With the 4.10 gears I really don't have any complaints. It'll get up and go pretty well. Keep in mind that I didn't but it for it's power. I bought it for it value (relatively low cost) and long-term durability. Easy to work on and do normal maintenance - I'll give it an 8.
CMOS
__________________
2001 Sport-Trac, 2WD, 4.0, 5R55E Auto, 4.10 gearing
"Faith in Government defies both history and reason."
  #39 (permalink)
Old 08-21-2007, 09:18 PM
ruffnready is starting off with a positive reputation.
Hmmm.... my 98 3.slow 5spd 4x4 off-road sport ext cab flareside... ENGINE > 6.5 though i dont expect it, this engine has minimal power and torque. u can beat the tar out of it and it still keep goin and the majority have pretty good longevity. it is fun to rip around in if you can get the engine whining high enough. truck is fairly capable for what it is....wisconsin winters, farm fields, hunting land, towing/hauling smaller loads (16' ish fishing boat, 2 place snowmoblile trailer)mileage is mediocre (solid 20 avg) not a bad lookin truck ...interior isnt terrible for a mid size.. also havent had too many major (non-normal maitenance) problems... only midsize ive ever had and it will be my last if ford doesnt make a more peppy engine with better mileage....overall id rate it a 5. definitely not the powerhouse of a fullsize nor has the roominess and the mileage quite frankly isnt where it should be at this day n age (i got 20 mpg avg in my old 91 I-6 4x4 auto which was ten times the truck the ranger ever could be) BUT ...i bought this as an economy vehicle to get through college with and it fulfills its purpose
RUFF
__________________
98 Ranger 3.0 5sp 4wd
92 f-150 5.0 4wd
95 Grand Prix 3.1
  #40 (permalink)
Old 12-03-2007, 02:39 PM
05Edge's Avatar
05Edge is starting off with a positive reputation.
Well, the last time I replied to this thread my truck was 4 weeks old... I loved it then, and I still liked it when I totaled it Nov 23... so so sad.
Hello 04 F150!!!
  #41 (permalink)
Old 12-03-2007, 03:39 PM
Mudflap is starting off with a positive reputation.
'02 XLT, 4X4, 4-door, 3.0 auto with OD, black with red pin stripes, Custom-made Harley emblem in each back door window with "Ford Ranger" above the logo and "Special Edition" below.
For overall transportation, easily a 10.
It's easy on the eyes and easy to take care of.
Dependability... well, it's never left me standing at the side of the road, but I've had a lot of mechanical problems with it.
Sound system would be rated reeeal low. Radio and cassette player work fine, but expansion joints on the highway make the CD skip. Ford garage says I expect too much from it. Plus, when I press the "eject" button it may or may not eject. Have had to wait two days before it finally decides to give the CD up. That may not sound like a major thing, but it destroys the entire driving experience for me. (Ford says it's me, not the system.)
Plenty of room in the cab (6'2 and 215 pounds).
Nice ride.
I would still recommend a Ranger to someone who wants or needs a lil truck, though, because Hay, if ya get a good one, you got a good one, and if you not, they're purty easy to work on!
  #42 (permalink)
Old 12-08-2007, 03:08 AM
mjlimo82 is starting off with a positive reputation.
'03 Scab 5 speed man, 89K. About 21 MPG in mixed driving.
Decent power; it will get up and go when you need it to.
The transmission/clutch sucks; doesn't always want to go in gear. Especially when it's cold.
Its a little small, but I deal with it. I wish I had a 4 door supercab instead of the 2 door.
It eats gauge cluster lights like I eat M&M's.
The front brake calipers are not very good; they warp VERY easily.
The back (non-sliding) window leaks from somewhere; in 4 years I still haven't figured out where.
Other than that it's been a great truck. No mechanical problems whatsoever, just little piddly stuff like that. If I had it to do over again I would, but with an automatic instead. Shifting gets old!
__________________
Current:
2005 Ford F-150 STX Regular Cab 4.6
1989 Dodge Ram 318/A727 225K - all original. My slow-to-get-going project
Previous:
1972 Ford F-100 360/3.03
1991 Ford F-150 Lariat 302/AOD - wish I still had it
2003 Ford Ranger SCab 3.0/M5OD
I don't claim the Chevy's I once owned...
  #43 (permalink)
Old 01-05-2008, 02:02 AM
3.0 98ranger is starting off with a positive reputation.
Smile
I'm guna rate my 98 3.0 2wd at a 10 all around, i have never been stuck in the snow or any element at that. i have a lawn service and this truck has had 182,500 hard trailer towing miles on it and all i have to do is run synthetic lubricants through it. one hint for the 3.0L, change the pcv valve, your power will return soon after.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
