White smoke after start-up
Hey Guys....I have a 2000 F-150 4.6 manual....when it has set for more than two days...a cloud of white smoke will come from the exhaust when I first start the engine, it does not do it at any other time It does not do it when I drive it everyday or every other day. The truck runs fine & starts up fine It did it this morning, my truck has not been started since Friday. Is there any cause for alarm?????
If it's pretty heavy, and the coolant degasser tank is empty or is showing signs of losing antifreeze, it might be the sign of a bad head gasket or other internal problem. If it's just a little puff, it might be a sign of normal water condensation that has built up in the exhaust system while the truck was parked.
agree it sounds like the start of a head gasket problem. I would do a pressure check on the radiator, to see if it holds pressure. If it does not them there is a leak some where if it is not pressent out side the engine or near the inside by the heater core then it is internal in the engine. two choces put a type of sealer in it or do the job proper and do a head job.
lance
lance
If it's condensation in the exhaust system, time is needed for the exhaust to cool and condensation to form. If it's a gasket issue, the defect may be small enough to require time for enough coolant to seep into the cylinder(s) to show up as a significant amount of steam when heated and forced through the exhaust system.
Two things I would suggest:
1. First thing in the morning, before the first start-up of the day (cold engine and coolant), check the antifreeze level in the tank. If it's below the marking for COLD, add a mix of 50% water/50% antifreeze until the correct level is attained. Drive the truck for the rest of the day, as you normally do. Next morning, again with a cold engine, review the coolant level. After only one day of driving under normal conditions, the level should appear to be exactly as it was the previous day. If it's down, the coolant is going somewhere, either as an external leak, or internal leak. If no external leak is indicated, then you could have a block or head gasket issue.
2. Same cold engine. Check the oil. Look for any evidence of water droplets on the dipstick, or a milky appearance to the oil. Either indicate the presence of water in the oil sump. While this can be demonstrated in an engine that isn't run a lot (condensation in the oil sump not being burned off because the oil never gets warm enough), the presence of water in the sump plus the white exhaust would have me thinking some very dark thoughts about the condition of the engine.
Now let me be a bit of an alarmist: If enough antifreeze leaks into a cylinder, and someone attempts to start the engine, a condition known as hydrostatic lock can occur. Basically, the piston moves up and attempts to compress the water against the cylinder head. Not good, as unlike the air/fuel mist that is usually inside the cylinder, water cannot be compressed. You can blow out the head gasket and/or bend the connecting rod for the piston in question. Expensive. If this was my truck, I would have it professionally examined immediately.
This is a late posting for this but for anyone that has this same problem, this could possibly be your PCV Valve(a 3 dollar part that pops in the top of your valve manifold) that needs to be replaced. The manual says to replace these every 15,000 miles. I went a couple of oil changes, using a high grade oil, thinking that my truck was ready for a new engine. I actually pulled into a station and had to pour in 3 quarts of oil. Every time I started my truck this huge embarrassing cloud of white smoke would blast out my tail pipe. I also used one of those tune-up in a bottle (Valvoline type) and poured in my gas tank before the next fill-up. This got rid of any valve clatter that was going on. I'm not sure if they were both related problems or not. 10,000 miles later my truck runs great and is burning a quart every 2000 miles. My truck now has 145k and is running fine. Not sure if this is related to your problem, but it's a cheap alternative to try.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
