300 6 cylinder thermostats
Old 10-20-1999, 08:34 PM
rklartz's Avatar
rklartz
rklartz is offline
So with the recent discussions, is a hotter thermostat than the original factory specs better for this type of engine.
Old 10-21-1999, 06:21 AM
slik's Avatar
slik
slik is offline
My .02 cents is that you want to keep the engine running as cool as possible. Now, you have to balance that against what type of systems you have that are temp sensitive. If you have a newer truck with all the computer wizardry, you want to stay at factory specs. The computer is looking for specific parameters and tries to compensate if it does not see those parameters. If you have an old beater like mine with no computer stuff, then you'll want to put in the coldest thermostat available as long as you generate enough heat to defrost the windows.
Just my thoughts,
Slik
Old 10-21-1999, 05:22 PM
Fast Eddie
Guest
Posts: n/a
I've read that putting in a cold thermostat (165-deg. F) on a computer vehicle will enrichen the mixture as the computer sees a "cold start" condition and will enrich the fuel curve, a "pull the choke" if you will; in fact, it is one of the 5.0 Mustang guys cheap go-fast tricks. I did it on my '91 300-6, and it didn't make a bit of difference other than bump the idle 200 RPM and make the temp needle barely move off its low peg.
I also pull a 6000-lb. travel trailer, and in the long hot Texas summer the 165 T-stat does its part in keeping the engine a tad cooler. Now that the weather is beginnimng to cool off, I am going to replace it with a 180-deg. balanced unit, and see if that will drop the idle back to where it is supposed to be, but if it isn't I'm going to go back to the factory 195-deg. part, and consider the 165 experiment a very limited success that I won't repeat.
Old 10-21-1999, 06:36 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
fordguy2100
Ford Truck Parts for Sale
05-13-2016 10:37 AM
Resendiz
08-04-2015 02:23 AM
f350on38s
10-13-2010 08:26 PM
greystreak92
1978 - 1996 Big Bronco
12-05-2002 03:17 PM
TorqueKing
08-12-2002 10:08 AM
Quick Reply: 300 6 cylinder thermostats
