Hot tranny!
Hot tranny!
Ouch! I think I lunched my C6 on my '82 F150. The tranny only has about 6K (TCI rebuild), but I think I got it overheated on a trip to Charlotte. The fluid (Redline) smells a little crisp, but the color is still good. It started when the truck didn't seem to want to downshift going up a long grade. We stopped for some dinner, then it seemed to work fine the rest of the way home. Now, however, it doesn't want to shift until you're either at about 4200 rpms or if I back off the throttle. Any suggestions, or is my tranny toast??
Slik
Slik
Hot tranny!
Got my modulator valve for $7.94 and replaced it. When I pulled the vacuum hose, I got fluid out of the hose. When I pulled the modulator, it drained about 2-3 quarts of tranny fluid (is this normal?). I installed the new modulator and did some adjustments and it seems to be working fine. It shifts at different points and the shift points aren't as hard, but it seems to be shifting correctly.
Thanks,
Slik
Thanks,
Slik
Hot tranny!
Slik, what you found is normal when the modulator valve fails. The vacuum on the hose going to the valve literally pulls the trans fluid right through the vacuum hose right to the motor to be burned in the engine. People who have an unexplained loss of trans fluid ( no visable leaks ) and erratic shifting should check their modulator valve because it could be bad.
