Help, no windows,radio, gauges,dome light?
Hello all, I`m new here and just bought my first 2002 7.3L Ford truck a few months back. Everything was working fine and I woke up the next morning and I noticed my dome light, dash board (gauges and warning lights), radio, & power windows were all not working?? The truck starts up just fine and runs good. I checked the fuses down below the steering wheel and they are all fine??
Please does anybody know where I may be able to look?
I had the SAME EXACT PROBLEM on my 2002 F350.. Turns out, my passenger side dome light bulb burnt out, causing the fuse to blow in the underdash fuse box. It took me awhile to find the problem, but when I replaced the fuse, it blew again. After finally removing the blown bulb, all was perfect.. I still havent replaced that stupid bulb.. Hope this helps you, I was frustrated for a bit..
It`s weird that one fuse controls sooo much??
LOL, glad to hear you found out the easy way. I had the same problem with mine when it was up and running. Mine ended up the ground on the drivers side kick plate wasn't connecting good enough. We went thought all the fuses a few times and were getting very upset and just started searching for grounds...
