Wanting to swap a 4.2L V6 for a 4.6L V8 in a 1997 F150
What parts will I need to swap out the 4.2L V6 for a 4.6L V8 in a 1997 F150? Will the frame mounts for the V6 line up with the motor mounts on the V8?
Thanks in advance.
I know somebody must know something about this swap. I just want to know are the frame mounts for the v-6 the same as the frame mounts for the v-8 or will I have to change them out also? I know that I am going to need the v-8 computer and change out the transmission also because I have just found that the v-6 and v-8 don't share the same bolt pattern.
