help required fuel injectors
hi, where do the fuel injector exit is it in the inlet port or is it in the combustion chamber like the spark plugs.
i should know this as i have just rebuilt the engine due to gasket failure but i have a mental block.
my need to know is i wish to fit a lpg injection kit and if it is directly into the combustion chamber then it maybe not posable.
here in the UK lpg propane gas is cheap so hopefully it will be into the inlet tract. thanks inadvance bokker.
thanks fplorer, that info helps a lot. here in europe propane is widely used as a very cheep fuel and the way it works is that you can switch to propane after starting up on petrol. the engine runs well with no loss of power due to the fact that it is injected into each cylinder just like petrol.(multi-point injection).
the other method of single point injection is less effective and prone to back fire into the inlet manifold.
thanks bokker.
thanks bokker.
