how often do you change your transmission fluid?
#46
I do the pump out method after the pan has been dropped, cleaned & the filter changed.
I then refill the pan with as much fluid as was removed, disonnect the cooler return line route it to my measured catch bucket & run the engine at 15 second cycles, as my tranny pumps 1 qt every 15 seconds.
I just don't like the idea of running the tranny pump dry. So I stop the engine every 15 seconds & pour in another qt.
About midway through, I do the shift through all the gears thing, to flush the valve body & clutches.
I do this 15 second start/stop thing, until the specified fill amount has removed, veified by the measured bucket.
This way I know Ive gotten most of the old fluid out of the valve body, clutches, torque converter & cooler.
If i've towed often I'll do the filter & full fluid change out every 20K miles.
After a full fluid change out I can feel the difference in the quality of the tranny shifts.
The fluid has always LOOKED ok, but I can tell by the difference in shift quality, it needed changing.
A complete fluid & filter change & pan gasket is WAY less costly than a breakdown tow, or a tranny rebuild, or a new tranny!!!!
I also do a power steerng system fluid flush & change at the same time!!!!
Don't forget, it's fluid gets tired too!!!
#47
#48
#49
#50
zbs60
22
03-02-2017 08:35 PM
snowmobile mike
1999 to 2016 Super Duty
11-30-2013 07:07 AM
