Headliner education and substitute material
I'me delving into replacing the hideous headliner in my '66 F250, and was wondering if there is a suitable material to cut the panels from myself? The original headliner panels are there to use as templates, so I thought, why not cut new panels myself?
Has anyone done this?
Also, was there supposed to be factory foam under the headliner, between the headliner and the sheet metal? Seems like a good way to trap moisture, and mine has a combination of clearly non-factory foam and what MIGHT be factory foam...
What is SUPPOSED to be there?
Okaaaaaay, everybody:
Sounds like it's been done before, just need to decide what material to use.
The heavier stuff that was mentioned (pegboard mat'l, paneling); how do you account for the curved pieces above each door, where they curve over the piece that's above the rear window? Do you just make it two pieces?
Maybe mine AREN'T stock (looks like stock parts that someone sprayed with foamy adhesive and glued blue fabric to. The adhesive turned to dust years ago and the dirty blue fabric sags and rubs the top of my head. Yech!), but the parts above the doors have a bend to the rear window.
