Iowa Chapter Join Chapter, Leader:
new tool
Old 05-21-2005, 07:13 PM
chrono4's Avatar
chrono4
chrono4 is offline
new tool
got a cutting torch today. i was in burlington getting some pool supplies, and i stopped into a pawn shop and saw a victor cutting torch set, used but not that bad of shape. asked the guy how much and he said 60 bucks. steal. he didnt know what somthing like that ran, but i tested it on a set of tanks he had, and it all worked, so i just got to get some gas now.
Old 05-25-2005, 08:25 PM
fellro86's Avatar
fellro86
fellro86 is offline
sounds like a good deal. You gonna leave it acetyline, or switch to propane? That setup works pretty good on propane too.
Old 05-28-2005, 10:13 AM
chrono4's Avatar
chrono4
chrono4 is offline
i might switch to propane, if i still cant afford a a acet. bottle in a couple weeks, ill switch over.
Old 05-31-2005, 07:59 PM
fellro86's Avatar
fellro86
fellro86 is offline
the regulator and all that are the same, you just need a propane tip. I generally run at 15 psi for the propane, and 40 for the oxygen. I also use a #1 tip. The #2 is too big and takes out too much material.
vasten
Garage & Workshop
24
04-13-2013 07:43 AM
barnfind 51
12-12-2011 10:56 AM
ATC Crazy
Garage & Workshop
05-26-2007 05:50 PM
Phinxter
Garage & Workshop
01-28-2007 02:59 PM
f-250.4x4.390
Garage & Workshop
25
02-25-2005 07:42 AM
Quick Reply: new tool
