Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-24-2005, 02:03 AM
bozo4ford bozo4ford is offline
Garage is empty, add now
bozo4ford is starting off with a positive reputation.
Leaky Clutch pedal
1986 Ford Ranger 2.3L
Hiyaall,
I filled my Brake and Clutch reservoir today and (maybe) overfilled the clutch reservoir too much because after driving around a little bit I noticed undernearth the clutch pedal on the kickwall..there was some fluid from the pedal. OR does this mean something else? I noticed in the engine side there was fluid that leaked out of the overfilled clutch resevoir down the tube and was visible where the fluid goes into the inside at the (engine)wall
Do I have to worry about the clutch going to the floor? Am I paranoid for nothing? Or when it leaks other than me overflowing the clutch tube...what does that mean then..(for future reference) In other words, is it normal for the clutch pedal to leak?
I hope all that it is, is that I overfilled it. Thanks, Bozo4ford
Tags
clutch, fluid, leaky, leayclutch, ranger, resevoir
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
