Recently, I decided to return to changing my own oil since I now own four vehicles and am tired of paying rubes at the local speedlube joint ever increasing $$.
So, after not changing my own oil in over ten years, I started with my 1980 Bronco Custom which has an automatic with the 351M engine and 95k original miles. I bought some Havoline 10w30 and a Wix oil filter.
Everything went fine but when I filled the crankcase, it took seven quarts! I did not overfill it and it has run fine ever since. It does not use oil BTW.
Does this mean this engine has a super oil capacity?
I have never seen a SM ford use for than 6 quarts, but again I havent seen everything there is too see. I don't know mauch about Mblocks, FEs and bigblocks.
Just read.....your owners manual, Haynes manual, Chiltons manual, Ford repair disk, etc, etc.....just look up capacities.....yikes!
I have a Haynes at hand......Chapter1-3 "Capacities" Engine oil with filter change 302 & 351 is 6 quarts. This is also listed on my chiltons CD.
hello...i have it here...you tell me
302.........6.0
360.........6.0
390.........6.0
460.........7.0
1975 thru 1979 (all)....6.0
Bronco(1973 and 1974)
six cylinder................7.0
1975 thru 1979 All).....5.0
i think your right...but i can't see it. i see 1975 thru 1979 all...5.0
