Seven quarts of oil?!?!
Recently, I decided to return to changing my own oil since I now own four vehicles and am tired of paying rubes at the local speedlube joint ever increasing $$.
So, after not changing my own oil in over ten years, I started with my 1980 Bronco Custom which has an automatic with the 351M engine and 95k original miles. I bought some Havoline 10w30 and a Wix oil filter. Everything went fine but when I filled the crankcase, it took seven quarts! I did not overfill it and it has run fine ever since. It does not use oil BTW. Does this mean this engine has a super oil capacity? |
no the 300 - 6 engine takes the same amount of oil. super cap oil pans are around 10 quarts of oil if i am not mistaken
Yeah the 351M, 400, 460 and the lowly 300 I-6 all take seven quarts with a filter replacement.
hmmmm i just had mine done and it only took 6. its a 351 and its not low.
Was the filter replaced?
All of my 302s and 351w take 6.
Also one of my dad's sevice trucks take 6, its a 96 f-150 w/300I6 and a 5spd. |
My 88 302 holds 6 with the filter. My 82 302 took 7.
I just picked up my 84 Bronco w/302 yesterday, and on the fan shrouod in that yellow auto parts paint somebody wrote "7 QTS oil" It must be true.
can i ask where you got your information on the 351m taking 7 quarts with filter change??thanks
I had my 302 rebuilt and the guy told m e it takes 6 with a filter change.
I have never seen a SM ford use for than 6 quarts, but again I havent seen everything there is too see. I don't know mauch about Mblocks, FEs and bigblocks.
4x4=7 quarts
you guys are kill'in me..where do you come up with this stuff..5-6-7 do i hear 8???
Just read.....your owners manual, Haynes manual, Chiltons manual, Ford repair disk, etc, etc.....just look up capacities.....yikes!
I have a Haynes at hand......Chapter1-3 "Capacities" Engine oil with filter change 302 & 351 is 6 quarts. This is also listed on my chiltons CD. |
hello...i have it here...you tell me
302.........6.0 360.........6.0 390.........6.0 460.........7.0 1975 thru 1979 (all)....6.0 Bronco(1973 and 1974) six cylinder................7.0 1975 thru 1979 All).....5.0 i think your right...but i can't see it. i see 1975 thru 1979 all...5.0 |
