Propane Attack!! (thanks Quad)
Old 07-13-2005, 07:58 PM
Fordafied's Avatar
Fordafied
Fordafied is offline
1st off let me give Quadzilla a BIG "thank you"!!! for all the help and info you provided in helping me set-up my Propane injection system. Man I love this stuff. I thought the truck ran like a bat out of hell before, but now it is awesome. I installed the Power Shot 2000 system with a 28 gallon tank. I had to mount the tank in the bed due to it being too big. I really did not want to do this, but I could not pass up the deal I got on it. Real simple to hook up and install. I still need to tweak the settings to ensure I am getting out of it all I can. It is getting a serious grin factor now. Cruising through town I can only think "who's next"
Old 07-13-2005, 08:11 PM
hoss1273's Avatar
hoss1273
hoss1273 is offline
Whos next ?????? Thats funny Fordadied >>>>>Go get em !!!!!!!!!!!!!!!!
Old 07-13-2005, 09:11 PM
Medic 66's Avatar
Medic 66
Medic 66 is offline
Does this do anything to increase your MPG? or just increase your fun factor? Just wondering.....
Old 07-13-2005, 09:26 PM
1997F-350's Avatar
1997F-350
1997F-350 is offline
sounds like fun but be carefull. dont put too many psi to her!!! you dont want any cracked pistons. i can only imagine what it must feel like!!!!!!!!!!!
Old 07-14-2005, 08:05 AM
Fordafied's Avatar
Fordafied
It states you can gain 2 to 3mpg. It does this by giving you a complete fuel burn in the cylinders. I really don't know yet due to just having installed it. You have a couple of ways to set it up. You can set it up for towing where the Propane doesn't start to flow until around 10psi or you can set it up for performance where it comes on at 2psi. Guess which one I have it set on. . I am learning a lot about it now thanks to Quadzilla. I think transmission upgrades are next.
Hope to get pictures in the gallery for those that are interested.
Old 07-14-2005, 08:13 AM
twildman's Avatar
twildman
twildman is offline
Your definately going to need some tranny upgrades to hold the increase in power, also if your running a chip, then you will want to be very careful on how much pane you introduce, because more than likely the chip will have some advance in the timing, and with propane, that automatically will advance the timing, so you want to listen for detonation very closely, and don't let the drugs flow to freely until you are sure of the programming.
Old 07-14-2005, 09:53 AM
Fordafied's Avatar
Fordafied
Any new news on the programming I spoke with you about?
Thanks
Brad
Old 07-14-2005, 10:09 AM
twildman's Avatar
twildman
twildman is offline
I will get it worked out for you one way or another, I am runnig a real sweet tow burn, I have tweaked it a few times and it is just about there, one little shift issue to work out and it will be done, and from there building the extreme is not a problem.
PaulsEdge
Alternative Fuels, Hybrids & Mileage
01-09-2017 07:09 AM
hmorder
Bio-diesel, Propane & Alternative Diesel Engine Fuels
10-22-2003 01:59 PM
97psd
04-16-2001 12:57 PM
Quick Reply: Propane Attack!! (thanks Quad)
