patching floor boards
Originally Posted by woodzracer
After looking a little closer (with my eyes open this time) I finally understand how the cab is put together. When the floor pan makes a 90 degree bend downward to form the inner part of the wiring channel it runs along side and is spot welded to the rocker panel. That is where I got confused. So now I know all I have to do is cut out that floor section, drill out the spot welds and cut a matching patch out of my donor truck, weld it back in and I'll be good to go. It looks much easier than i thought, but thanks to all for your help.
Ripcity
10-12-2013 09:45 AM
1999, automotive, boards, bronco, f250, floor, floorboard, floorboards, ford, gauge, metal, patching, replacing, sheet, truck
