Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-12-2005, 09:09 PM
88treadbrite_150_4spd 88treadbrite_150_4spd is offline
Garage is empty, add now
88treadbrite_150_4spd is starting off with a positive reputation.
D.I.S. 8 plug head
i have a 92 ranger and i am starting to swap in a turbo 2.3 out of a 86 TURBO COUPE. i would like to know if i can use the head off my 92 on it so it will have the distributerless 8 plug ingition system. i thought i read some where that i can do this. now i can't find where i read it. so any help would be great. could any one who has expirience on this swap please give me any tips on problems that were encoutered that i should watch out for. i hope to up and running in a couple weeks. thanks
  #2 (permalink)
Old 06-02-2005, 01:59 AM
Samsonitesamsonite's Avatar
Samsonitesamsonite Samsonitesamsonite is offline
Samsonitesamsonite is starting off with a positive reputation.
t could work with some fabbing, you will have to splice the plug wires together, then run them to the dist. removes the coil packs and everything
__________________
RIP all my fords.
  #3 (permalink)
Old 07-12-2005, 12:58 PM
F-Liner's Avatar
F-Liner F-Liner is offline
F-Liner is starting off with a positive reputation.
Ok, my experience with the 2.3 is limited to a 78 Pinto and a 79 Mustang. And, other than knowing the 8 plug head was available for a short time, I'm not completely up to speed there either, but (now for my question), is there any reason why treadbrite wouldn't be able to keep his DIS system? I'm really not seeing why the DIS would have to go away to use the turbo block? Can the dist not be run empty to provide the oil pump drive?
__________________
Paul
00 Expedition 4x4
97 F-150 4x4
Kansas Chapter
  #4 (permalink)
Old 07-13-2005, 10:51 AM
Quote:
not the best idea to splice the plug wires.
here is what i did
i started with an 86 2.3t and ripped it apart then i took the 92 2.3 D.I.S. motor and ripped that apart then i took the rods, pistons, and oil pump out of the 86 and put them in the 92 block then i used the 92 D.I.S. head, intake, and throttle body. i put the E6 and turbo from the 86 on and stuffed it in the ranger. as for the D.I.S. i am running it with the ranger EEC wth low boost but i plan to get a turbo EEC an LA3 i hope but any of the turbo EEC's will run the D.I.S. the only problem is the crank trigger the turbo block has to be drilled and tapped for it. then there is the problem with N.A. brlocks not having the drain for the turbo so that has to be drilled and tapped also. so there you have it it can be done with a little time and some cash.
AL
Tags
23, 23t, 8plug, dis, ford, head, plug, swap, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
