What power steering box to use on a '57-'60?
I searched the archives, and didn't come up with anything... sooooo, what power steering box easily adapts to the '57-'60 Efonhunert? Is it a Toyota? A Jeep unit? Which one?
Has anyone ever set one up cross steer?
Has anyone documented a power steering how-to on FTE for these trucks?
Thanks guys!
Sam.
Thanks guys!
Sam.
I've doing a lot of reaserch on the Toyota PS conversion for my 54. I found that No Limit Engineering makes a kit for the 57-60 to convert it with the Toyota box. The only difference is the Pitman arm. It looks like the installation is the same, and there are several tech articles online (Classic Performance Parts, Classic Trucks magazine).
my 58 is set up with cross steering. the steering box came out of a 78 LTD. Note where the frame was heated up and banged up for the pitman arm to clear the frame. also see where the draglink was connected to the passenger wheel. it has no bump steering either and a very smooth ride.
it drives great. i can easily hang u-turns quick. park without any stress to my arms and no bump steer.
you will have to move the steering column up a few inches from the original location. get a u-joint or a rag-joint and your fine.
i need to get rid of the rag-joint and get a u-joint instead cause of the angle its at. i could use a 1 1/2 " drop to the column but the wheel would rub on my lap.
i also have a steering stabalizer connected to it.
