Expedition keyless entry programming
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Is the procedure in your owner's manual....if not
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
programming
To program the remotes
1. Turn the igngiton from off to run 8 times within 10 secs ending in the run position. The door locks will lock and then unlock. press a botton on the remote. the car will lock and then unlock again. press a button on the second remote. Turn the ignition off . Done.
You have to program all the remotes at the same time. hope this helps. let me know if you need something else.
Originally Posted by madspence2
Does anyone know how to program the door code? I bought a used 99 and I dont know the code.
Thanks
Thanks
f1501987
03-03-2012 08:56 AM
oncman
1997-2006 Expedition & Navigator
07-12-2003 04:11 AM
ghlacy
09-10-2001 09:11 AM
