Manual tranny question
I have a 01 F350 psd and all the gears seem to function fine but second if you are sitting at a light clutch in and in second when you go to let out on the clutch the stick will pop out of gear is that just the sincros going out or what? all the other gears work fine and even when you have shifted into second it will not pop out with clutch enguaged any help would be great.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Originally Posted by Ford#1
I hope that someone has an idea of what it is I want to get it fixe asap
Does it feel mushy when going into second compared to the other gears? Grind? Ever pop out once you have it in gear? Those symptoms are all indicative of an internal problem and the only way to fix is to remove transmission, dissassemble and repair.
v650
11-05-2013 10:44 AM
84 f250 6.9
38
01-10-2010 11:50 AM
