Offroad & 4x4
Will an 99 F250 SD axle work for SAS 84 F250
Old 04-25-2005, 04:42 PM
bonechief's Avatar
bonechief
bonechief is offline
Well finally got my lift and tires all ordered....Went down to the local salvage yard to buy my Dana 60.....The salvage yard said he had 3 just waiting to be bought.....Well he was mistaken, so now i have a lift and tire and no axle......I did find a few front ends out of 99 and newer superduties will one of these work or is it to much hastle......Any info will be appreciated.....
Old 04-25-2005, 05:41 PM
bremen242's Avatar
bremen242
bremen242 is offline
Those SD axles are Dana 50s and they aren't worth swapping in.
you could get a 2002+ SD axle (Dana 6), but they still aren't that great. They have unit bearings that go bad alot, and they are $450 bucks a side (for the bearing itself).
find an '85.5-98 axle, and you'll be a lot happier. an '85.5-91 axle and it is stronger (has kingpins instead of balljoints).
Old 04-25-2005, 08:16 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
like bremen said you are looking at those crappy, POS unit bearings which are weak. also you will have 2 different lug patterns to deal with... the front beaing a metric pattern
-cutts-
Old 04-25-2005, 08:43 PM
GreenSubmarine's Avatar
GreenSubmarine
GreenSubmarine is offline
Bremen and Fishy are right - as much as you're in a hurry to finish the thing up, the SD axles are way more trouble than you probably want to deal with. Keep looking for an older D60.
Good Luck,
Ernie
Old 04-26-2005, 10:48 AM
bonechief's Avatar
bonechief
Hey thanks for the info i will keep looking then
Old 04-26-2005, 02:08 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
ya know its not uncomon for them to be found on ebay...check there...
Old 04-26-2005, 05:00 PM
mustange70's Avatar
mustange70
mustange70 is offline
You might want to grab a rear axle if you can get it for cheap, then convert a 10.25 you have to rear disc brakes (or just grab the parts you need, like the mc and booster for example) I can't remember who told me this (someone on here) but all the stuff just swaps over to the 10.25" axle, you just need to use rotors from the front of a 87 and up f-350/250 4wd truck, i believe that is right.
Old 04-26-2005, 08:56 PM
fishmanndotcom
really? hmmmm! i think i might smell another project coming on, lol
-cutts-
Old 04-26-2005, 11:36 PM
mustange70's Avatar
mustange70
It'b be cheap as there's sure to be a SD sittin at a wreckers somewhere.
T Acton
12-21-2012 07:58 PM
Jessef250
10-10-2011 11:20 PM
tpafire5
04-14-2011 03:29 PM
65F1005.8
22
03-04-2011 10:02 PM
Moore558
12-20-2007 11:11 PM
Quick Reply: Will an 99 F250 SD axle work for SAS 84 F250
