Free Stufff
Free Stufff
I got a stock intake manifold and carburetor from my '84 BKO w/ a 351W. The manifold has EGR, but is corroded a bit around the water port by the 8th cylinder (closest to driver) and the port infront of the 4th cylinder where the radiator fluid runs, may need to be machined, but like I said, it's free so don't complain!! I also have the 2 barrel carb. that most likely needs a rebuild seeing as I don't think it was making any vacuum when it was on. They both ran, I took them off b/c I blew my intake gasket and was gushing out radiator fluid all over the place, and after noticing the corrosion I went ahead and bought a performance Edelbrock intake and manifold. 1st come 1st serve basis. If you're local to Houston, you can pick 'em up. If not, shipping is on you.
Keith
~Houston, TX
<!-- / message -->
Keith
~Houston, TX
<!-- / message -->
