Other grades of diesel
Old 04-20-2005, 07:18 AM
csramsey640's Avatar
csramsey640
csramsey640 is offline
I saw recently that there are more grades of diesel fuel than what is available at the pump, such as 4,5 and 6 used in large locomotives, turbines, etc. Does anyone know the difference between these grades and reg road diesel?
Old 04-29-2005, 12:59 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Diesel fuels are covered by the ASTM D975-04a specification, which describes seven grades of diesel:
[Grade No. 1-D S15, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 15 ppm.
Grade No. 1-D S500, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 500 ppm.
Grade No. 1-D S5000, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 5000 ppm.
Grade No. 2-D S15, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 15 ppm.
Grade No. 2-D S500, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 500 ppm.
Grade No. 2-D S5000, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 5000 ppm.
Grade No. 4-D, a heavy distillate fuel, or a blend of distillate and residual oil, for low- and medium-speed diesel engines in applications involving predominantly constant speed and load.
Heavier fuel oils Grade 5 and 6 (residual), which are used primarily for heating purposes, are described by ASTM D396.
Find more info here. http://www.dieselnet.com/standards/fuels/us.html
Old 05-17-2005, 01:15 AM
F-150XLT's Avatar
F-150XLT
F-150XLT is offline
There was also once a grade 3 diesel that is no longer in use. Canada has some other system for classifying diesel.
sgnen
1999 to 2016 Super Duty
05-11-2016 10:17 AM
robpelkey
6.4L Power Stroke Diesel
06-03-2011 11:53 AM
bonehead_98
10-18-2007 11:38 AM
blueheal
Bio-diesel, Propane & Alternative Diesel Engine Fuels
12-12-2005 10:45 PM
Motown Fire
01-31-2004 02:36 PM
Quick Reply: Other grades of diesel
