Cleaning frame rails
If you have an Auto Zone nearby, they sell the same thing as the Castrol as "Coastal" brand for a couple bucks a gallon less. It is great stuff! but be sure to wear gloves and eye protection, like the others have pointed out, it's strong stuff! If you have paint on the frame and want to keep it, try using a piece of very fine Scotchbrite; hardware stores sell it in the wood refinishing section. Can be hard to find, but it's usually black and feels almost like felt. It's durable, does a great job and won't take off solid paint.
I completely forgot about the oven cleaner routine. LOL.... It really works good. I think I'll scrape most of the crude off and use the wire brush routine. Since the truck is on stand in my garage, power blasting it with steam or water is not an option. Got some good ideas though. Thanks guys. I'll check Wal mart out tomorrow.
Another good grease cutter is "Greased Lightning" its very similar to Simple Green but a bit cheaper. You can find it in most hardware stores, etc. I have a small parts cleaner filled with it. I use it straight without mixing it down, it'll take parts down to bare metal overnight. For large parts like ther frame or an engine block I usually end up resorting to engine cleaner.
I'm going to try the Castrol and/or the Coastal cleaner and see how it goes
lacquer thinner is my personal fav.
Good one, I'd forgotten to mention lacquer thinner. It does a good job of crud removal when you don't want to scratch or damage the underlying paint or metal. It will soften that hardened crud and make it possible to wash the crud off with Gunk or some other petroleum based solvent.
I've tried dipping entire engine blocks in a caustic solution, but it needs to be warm to work. A cold caustic bath is useless. My next trial will use a turkey fryer burner under a 55 gal drum to warm the lye. I'll bet that will scour the crud from iron.
Years ago when I worked in the factory, we used to take that orange cleaner and mix it 50% with Stoddard Soivent. It worked great for cleaning the forklift engines and transaxles. We sprayed it with an air pressure spray gun at 80 PSI. You need to be careful getting it on any painted surfaces. I recall it kind of streaked the orange paint on the Clark Forklift.
Rod
Rod
