visors
visors
I had an 84 Bronco II with sagging visors. I took them out and got a pair of pliers and and couple pieces of thin wood and squeezed the edge of the visor along the arm. I used the pieces of wood to keep the pliers from tearing or marking the material on the visor. Works like a charm.
Steve
Steve
saging visors
I had the same problem with my 86 Bronco and my F-150. I simply got a pair of visors out of an 87 to 91 . They have a small clip out at the end that holds up the visor to the roof of the cab, just mark and drill two small holes and fasten the clips,go easy so you don't punch into the outer sheet metel of the cab with the drill bit. The other end of the newer visors will line right up with the old holes. Note: put the newer visors on, to line up the clips.
