ZF5 Fluid
My brother works for Waste Management and after they had several ZF failures back in the early '90's the factory recommended they use 15W-40 motor oil in the transmissions instead of the usually recommended ATF
The box in my '90 F-350 with 148K was a little noisy and I put Mobil One 15W-40 in it and it seemed to quiet things down
You might have a little problem shifting in really cold temps until the trans warms up, but I've not seen that so far with mine . . . . but then it seldom gets really cold down here in Biloxi
Don
Don
