2v carb problems
2v carb problems
My 77 F-150 351M 2WD auto sat for most of the winter. When I fired it up this spring gas came up throught the 2 stove pipes in front of the choke butterfly. I rebuilt it setting the "new" float at 7/16" from the top edge per instructions and I just tried it again. Same problem gas coming up through the stove pipes. Should I trash the thing and get a Holley replacement or what?
Thanks Jeff
Thanks Jeff
The retainer is a wire that clips onto the float shaft (pin that the float pivots on), and then the retainer goes around the needle seat. Most needle seats (also called fuel inlet seat) have a groove cut into the exterior of the upper part of the seat, and the retainer clips into that groove. The retainer wire sort of looks like a retainer that a person with braces uses. Hope that helps, sorry not hi-tech enough to post picture or diagram.
WhatsAChevy?
20
10-17-2023 07:21 PM
Dago Red
05-06-2016 02:50 PM
Mdc9966
09-16-2015 11:20 AM
