Bronco Will Not Start With Key
Probably a bad solenoid, or else it's the ignition switch or a shorted out wire between the ignition switch and the solenoid. Try the solenoid first, it's cheap and easy. Just because you can jump the solenoid does not necessarily mean that it is good. It could have a broken contact inside of it, so when you jump it you are jumping around the bad contact.
Same Problem
I have that same problem with my 1986 bronco. About 50% of the time it wont start with the key. I still have yet to find the short. Since you said you replaced the solinoid its most likely a short between the ingnition switch and the solinoid. I for some reason couldent find where the short was occouring in mine. I ended up installing a switch that is only on when you push on it. I wired the switch to be hot only when the key is on then a wire went from the switch to the solinoid where I then spliced it into the little red wire on the solinoid. this essentially created a backup ignition system. Depending on your broncos condition I would only do this as a last resort being that mine isnt showroom condition any more. I hope that you have more luck than i did than finding your short.
OOOPS! I didn't see there that you had replaced the solenoid. Sorry! So move along to my next suggestion and check for a shorted out wire between the ignition switch and the solenoid (the same as what BRK was talking about when he said to check for 12V at the solenoid). If you do not get 12V there, and you probably won't, work backwards until you find it - also you could start at the ignition switch and work towards the solenoid. That would probably be a better idea since there is a good chance that the switch itself is bad.
Anyway sorry for any confusion!
Hey guys, one other thing to think of.....
I had the exact same issues with my '91. It would intermittently not start with the key. I replaced the ignition switch. Then it got to the point where it wouldn't start period, but it could be jumped across the solenoid. So I replaced the solenoid. Still no joy!
I tried this, that and the other and finally sucked it up and took it to the dealer. Guess what? There is a $50 aluminum rod that runs down through steering column. When you turn the key it cams this rod downwards through the steering column to hit the actual ignition switch down somewhere near the dashboard/column junction. Apparently the rod will 'flatten' out from use - effectively making it shorter - and then it won't go far enough to actuate the bottom switch!
I thought $50 was bad for the rod, but they charged like $200 labor to instal it!!! YIKES! Anyrate, they fixed it and it works fine now.....old key switch works again too!
Just something to think about......hope it's not that bad for you!
If it's the actuator rod, I got one the other day from Furd - about $11 down here. It's a royal pita to install, so the $200 was probably money well spent. It took me two evenings of pure frustration to do it. I could do it quicker having been in there though. Satan himself must have designed that linkage. Or so I yelled at the steering column. It didn't help.
To clarify, there is a cast metal actuator inside the column, just behind the turn signal switch - there is also a steel rod that attaches to the actuator, The rod links the starter switch to your keyed switch - the cast metal actuator seems to be the weakest link, and the pain to replace. I probably confused some folks when I called the actuator an actuator rod. The two are pinned together.
Thanks all for the tips so I still haven't tracked it down, replaced the ignition switch, it appears there is a short between the switch and solinoid. I am new to modern cars with this many wires under the dash, how do I trace down where this wire runs or is this just a job for finding the right wire on the switch and running it directly to the solinoid to get around the short ? THanks again
