Water leaking- this one is a bit different..check in please?
Old 03-14-2005, 09:00 AM
YOMAN's Avatar
YOMAN
YOMAN is offline
Hey there..
I just noticed that theres "catch water" (black rubber) thing where the slide goes (see pix http://pic6.picturetrail.com/VOL164...06/88995890.jpg ) but i couldnt feel any WET or soak on carpet or back side carpet..then next few hours its gone and back to dry. Even i doubled check 3rd brake light its completed dry and no spots water or anything inside the 3rd brake lite. i guess thats normal ??
My suspect that water got in from where i pointed my finger at corner maybe i ll try to add some kind of glue.
http://pic6.picturetrail.com/VOL164...06/88995908.jpg
Thanks!
YOMAN!
Old 03-14-2005, 10:11 AM
lardman's Avatar
lardman
lardman is offline
Yoman, both links are dead. Is this back by your rear sliding window?
Old 03-14-2005, 01:05 PM
KevinM's Avatar
KevinM
KevinM is offline
You sure it's not getting in under the brake light. What happens is water get, in under the gasket and drips down the headliner. The third light will not have water in it.
Old 03-14-2005, 02:08 PM
YOMAN's Avatar
YOMAN
YOMAN is offline
yeah like i said i doubled check 3rd brake light leaking and headliner and theres nothing wet or soak and also back side carpet (top).
Its only INSIDE the black rubber shape like this I_I (see pix #1).
http://pic6.picturetrail.com/VOL164/...6/88995890.jpg
http://pic6.picturetrail.com/VOL164/...6/88995908.jpg
Try above here..
YOMAN!
Old 03-14-2005, 02:30 PM
lardman's Avatar
lardman
lardman is offline
Those pics work. Is the water running over onto the back panel? Notice the small hole in the seal, just to the right of your finger? I believe that is a drain and there is another hole in the ring that holds the glass panes in (you can't see it unless you remove the module)...that looks to be a drain too. They can't completely seal the slider (there is a small gap where the vert and horiz seals in the slider opening come together).
