How to replace your Super Duty Ball Joints
#736
Thanks, the second seal did go in with no issues. I think it was the driver tool, I made. It needed a little more surface area to contact the seal. I cut it down so the contact area was greater.
My second axle seal (left side) is in good shape, so I'm keeping it.
I think the instructions should remind the user to check the disk brake backing plate orientation, BEFORE, bolting the hub together.....Doh,
I have done the same thing with the backing plate!
#738
EDIT: New part number is Spicer 2019816. Same price.
#739
In the process of balljoints on 2001 f250 4wd.
Everything came out easy. Even the balljoints came out fairly easy.
Now trying to press in the new ones with the autozone balljoint kit and the additional Ford Add on. I still can't seem to press in the first balljoint all the way. The kit doesn't have a wider/shorter piece of pipe to get it done.
And it SURE helps to have a vise and an impact wrench. SO much easier.
I might just have a shop press the balljoints in all the way. or should I just spring for the press? lol. I'd like to buy it but I don't have much need for it after this job, I think
#740
I bought a 20-ton press from Harbor Freight for my balljoints, and I've used it countless times since then. Rear suspension bushings for my '97 Cougar, even little stuff that was tough to get apart. Just be careful.
If you have one near you, try to find a flyer from Harbor Freight with the 20% (or whatever) coupon. They might even have one on their website.
#741
Wouldn't you still need the various metal pieces to make it work for balljoint pressing?
#742
I have a huge array of large sockets, pieces of pipe, old manual transmission gears and a bunch of other stuff that I use for pressing pieces. But Harbor Freight has that kind of stuff too. I think the press came with a few plates to place pieces on - or maybe I had to buy them, I don't remember.
#743
#744
I wouldn't do it that way, matter of fact, I didn't do it that way. While he says it's "cast iron" and it's really not, it's forged, I still wouldn't put that much force into the knuckle itself.
Also, he's an idiot - he's not wearing eye protection. That right there should tell you something.
#745
So how would you push in a balljoint without pressure on the entire knuckle?
#746
On our Dana 50/60 knuckles the ball joins are pressed in from the bottom. Stand the knuckle upside down on the plates (plates arranged so there's a hole in the middle), use a 3/4" extension or pipe or tranny shaft, or something long enough and put it through the lower balljoint hole and use a socket. Press balljoint in. That's for the upper.
The lower, same idea, but get a big enough socket to receive the entire balljoint, and arrange it somehow to stand the socket on a plate with the knuckle sticking down through the "bridge" (not sure how to describe it) of the press.
Proceed with caution
#747
The 12 ton is on sale w HF, but not the 20. Looking for a coupon.
edit; found the 20% coupon, same ad !
#748
Thanks Krewat, you made me buy the 20ton press.. :-)
Can't wait to use it. Still need to put it together.
First press in the uppers, then see how to do the lowers. I don't think (not sure) the knuckle fits in between the lower 2 supports that the plates rest on. ? Will see. Might need to create some type of U shaped bridge to hold it.
#749
Put the press together. Pushed in the first balljoint. wow, this thing doesn't blink an eye doing that.!
Can't figure out how to do the upper. The knuckle doesn't fit in between the lower 2 bars...hmmm
edit: I did the lower first. They are pushed in from the bottom, the threaded part points up.
edit2: correction, pushed in from top...gets confusing
#750
alright, figured it out. I supported the top and bottom of the knuckle with a piece of pipe and a bolt with nut that sticks inside the pipe. I then tighten the nut so that the bolt acted as a support. I then pressed in the balljoint from the top. Worked excellent !
Already installed them back on truck. Axles are back back. new seals. lubed up the inner bearing. Took apart the hubs and lubed them up. Front diff new fluid. New rotors. flushed brake fluid. and a crapload more.
