Edelbrock vs. Holley
Old 03-09-2005, 10:29 AM
dakota_viking's Avatar
dakota_viking
dakota_viking is offline
OK...I'll declare my ignorance right now....That's why I'm asking all of you.
I am in the process of rebuilding my 460 to go in my '76 F250. The old Holley on the motor is very well shot.
I will be purchasing a different carb and I would like an HONEST opinion of what to go with. The engine will retain the stock 4 bbl intake.
I know that holley carbs always had a problem with blowing out power valves.
I have been hearing good things about the Edelbrocks so I wanted to know the opinions of others.
So, Holley or Edelbrock and what cfm?
Thanks!
Old 03-09-2005, 02:13 PM
73Custom's Avatar
73Custom
73Custom is offline
It all depends on your personal opinion. I prefer Edelbrock. I've had bad luck with Holleys in the past, but my Edelbrock has been running great with no trouble for over 5 years now. The Holleys generally take more gas and require frequent tuning and maintenance. Where as the Edelbrock doesn't need the constant attention, and seems to runs smoother and is more dependable for a year round daily driver. The new Holley truck avenger carb is good, with protection for the power valves, but I'd still get a Edelbrock. I'm running a 600 cfm with electric choke on my '73 2wd stock 390 and it runs great.
Marty
Old 03-09-2005, 02:57 PM
Momudder720's Avatar
Momudder720
Momudder720 is offline
I concur. Running a 600 edelbrock on my 351W and a 650 on my 460, and nary a problem from either. Never hear about power valves blowing out in the edelbrocks...
Old 06-14-2005, 02:31 PM
Motley0108's Avatar
Motley0108
Motley0108 is offline
Edelbrock
I would go with a 650 or 700cfm for such a big motor it let it beath also you sould so with a Edelbrock Intake
Old 06-14-2005, 04:20 PM
Ecuri's Avatar
Ecuri
Ecuri is offline
For CFM check this out:
www.slowgt.com/Calc2.htm#Intake
Edelbrock is way ahead in my book. Much easier to jet. It seems to me that most carbs come jetted too fat out of the box and can stand to be leaned out. The AFB is really easy to tune and you should order the jet/rod/spring kit with it, I think it is about 50 or 60 bucks for the one with everything you would ever need to tune an AFB.
GL
Old 06-14-2005, 04:23 PM
proeliator's Avatar
proeliator
proeliator is offline
A 670 Street Avenger Holley if you are really concerned about mpg and your motor is bone stock, otherwise a 770 SA Holley, especially if you have free flowing exhaust. That would be my preference. I've used them all, but I'm not a fan of eboks, although I agree that they are easier to tune for the novice. Honestly, unless you are building your motor for power, either brand would be fine.
edit: Holleys have had "power valve blowout protection" for some time now.
Old 06-14-2005, 09:45 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I use a 750 Edelbrock on my 460 and it runs great.
Old 06-15-2005, 07:36 AM
smoke n tires's Avatar
smoke n tires
smoke n tires is offline
holley is the best. edelbrocks work well but they give your engine about 85% of what it should have. a 460 NEEDS a 750 holley, vac secondaries. the power valves wont blow out anymore, in the early 90s holley installed a check valve to protect it so on a newer carb youll be safe. PLEASE GET THE HOLLEY, edelbrocks are non-tunable ive had both...........if you do some basic research and learn how the holleys are tuned and adjusted you will have a tire blistering big block.
Old 06-16-2005, 02:16 AM
Motley0108's Avatar
Motley0108
edelbrock
[QUOTE=smoke n tires], edelbrocks are non-tunable P.O.S's. QUOTE]
Sorry edelbrock's are tuneable
Old 06-16-2005, 02:43 AM
highboy 74's Avatar
highboy 74
highboy 74 is offline
Go with the Holley 770 SA. Built to a higher standard.
Old 06-16-2005, 12:24 PM
dakota_viking
Thanks Guys!
I wasn't trying to start any battles...let's just agree to disagree.
Thanks for all the replys.
Have a good weekend!
Tim
Old 06-16-2005, 05:40 PM
BroncoRoadKill's Avatar
BroncoRoadKill
BroncoRoadKill is offline
I have a 600 holley 4 barrel on my dune buggey and it has back fired many times toying with the timeing and such, never blown a power valve.
Also, the chibbie I am driving has a edelcrap on it and I have too retune every time the weather changes, witch means every day here in south texas.
Old 06-16-2005, 09:57 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
I really don't want this thread to turn into another Holley-vs-Edelbrock peeing contest. If this thread keeps going the way it is, I will be forced to remove it.
sony420
03-29-2015 12:54 AM
7636074460
04-02-2012 03:55 PM
whisler
30
03-20-2011 10:03 AM
imlowr2
08-28-2008 01:51 PM
otis348
10-08-2004 05:12 PM
Quick Reply: Edelbrock vs. Holley
