New Hope for 2005 radio aux input
I don't see how this corrects the aftermarket sat reciever issues with current Visteon head units. Since now you have to use FM modulation, and FM tuner is limited in frequency response (20hz to 15Khz), so you loose it anyway. This device only corrects an OEM unit if it has rolloffs preprogrammed and has line level outputs then you need the equipment on the other end.
You have to buy a set of amps and additional speakers. If you use the same speakers you may have impedance problems since the output amp of the head unit will be attached to the current set of speakers. The only way you could do it using the same speakers is to have a selector switch setup to either allow the sat amps or the head unit to be in use.
