Good auto trans for a 300/6
Hi Iam new to the board. I have an 85 Bronco with carbureted six , 4 speed manual tranny. Is there any good auto tranny for that year and engine that I could look for at the salvage yards. Will they work off an 8 cyl ? Are they any good or worth the work.I understand that I will need a new radiator,lines ,linkage and flywheel Thanks, Mike
on
C-4 or C-6 have both come attached to the 300 I-6 from the factory & as long as you have the Proper Torque coverter for an I-6, a C-4 or C-6 off a 289, 302 & 351W will do just fine, they use the same Bell Housing as the 300 I-6.
Cheers
Colonel Flashman
Red '58 M-100 Built 300 I-6 (400 FPT & 300 HP w/ 10:1 CR) w/ HP C-4
Blue '58 M-100 Panel Truck
Cheers
Colonel Flashman
The AOD and E4OD also came hooked to these at various times if you want an overdrive. The c4/c6 seem to last longer in my experience.
Although the E40d would be a harder swap due to the electronics.
Don't forget you will also need a shifter of some sort in addition to what you list.
And if you use an aftermarket transmission cooler, you can keep your stock radiator.
Jim
Jim
on
Originally Posted by Col Flashman
"as long as you have the Proper Torque coverter for an I-6,"
Colonel Flashman
Colonel Flashman
The 300 I-6 uses that small block bolt pattern, so any trans with that pattern should theoretically work.
on
You lucked out then, because they are rather different due to the Fact that the Stall Speeds are quite a Bit lower for the I-6 which are in the Teens.
There are others things as well that I just can't remember as present.
I just went through this w/ My Tranny Specialist & we had to do a Bit of research to make sure we got Everything correct for my 300 I-6 & C-4 because I basically Started from Scratch on Building them From the Ground Up.
Cheers
Colonel Flashman
Cheers
Colonel Flashman
are there any numbers on the tranny to find out which one it is? only thing i know is i have a 3 speed auto. after reading this im curious. Its an aftermarket tranny too. truck used to have a manual in it, because the clutch pedal is still sitting there, and were the shifter used to be I have a B&M shifter. I didnt put any of this in the mechanic that had it before me did.
Originally Posted by Hooker Bob
I remember reading about an aftermarket controler for the E4OD that allows you to lockout the O-drive and converter lockup. This would be a super setup behind that 300. The E4OD is as tough as the C6 I had one behind a monster 460 with 375 horses at the wheels it never failed.
Pat
Pat
I'm using a TCS controller from Bauman Engineering, loock at www.becontrols.com
If you want some more "brain" look at www.compushift.com
The problem w/ the AOD & E4OD is the way that the TV Cable is attached, as the bracket has a tendancy to break & then you Burn Your Tranny Up before you even Know you've a Problem.
