1995 F150 fuel pump problem?
I'm having the same problem with my 93 E250 4.9. I have a single midship tank with a In tank pump/sender unit. there is no high pressure rail pump on my van but you might have a low pressure In tank fuel pump/sending unit as well as a high pressure rail pump on your F150. How did you do the relay test???. I'm trying to find out if I have power going to the In tank pump. I checked the fuel shut off switch and it was ok.
toycraftusa
02-03-2008 12:40 AM
