Computer Chips & Tuners
How to remove top speed limiter
Old 02-25-2005, 06:06 PM
harleyd8's Avatar
harleyd8
harleyd8 is offline
I have a 02F150 with a 4.2 V-6 and 5-sp. This thing cuts out at about 95
mph. Scared the bejeezus out of me the first time it happened. I do not
need this to regularly speed but have actually needed the speed a few
times passing on the interstate and while in traffic in large cities(Atlanta)
Thanks for any help anyone can provide.
Old 02-26-2005, 10:43 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
What's the 4 digit PCM code, from the white sticker on the passenger side door frame near the hingers? I can remove it with a Diablo or SCT chip/tuner.
Old 02-27-2005, 06:55 PM
harleyd8's Avatar
harleyd8
harleyd8 is offline
Ken,
I have looked and can not find the code you refer to. I am looking on the sticker that
has the tire pressures on it. Is this the correct one. I can't look now because it is
raining but I will look tomorrow when it clears up. Thanks for the response.
Old 02-27-2005, 07:45 PM
ford5.8's Avatar
ford5.8
ford5.8 is offline
The sticker is on the door ledge on the cab to the front of the pickup.
Old 03-02-2005, 10:12 AM
harleyd8's Avatar
harleyd8
harleyd8 is offline
Mr. Payne,
I found the sticker thanks to ford5.8's help. Sorry for the delay.
The 4 digit code is EFK1
Thanks
Old 03-02-2005, 02:55 PM
Eric Brooks's Avatar
Eric Brooks
Eric Brooks is offline
The EFK1 calibration shows a speed limiter at 127 MPH
Old 03-02-2005, 07:36 PM
harleyd8's Avatar
harleyd8
harleyd8 is offline
Mr. Brooks,
Thanks for the reply. I am not sure what is going on with my truck then
because at about 96 to 98 mph it either cuts the ignition, the fuel, something
because everything gets very quiet until I drop about 3 to 5 mph and then
power comes back in. If I had the 127 cut out that would be perfect.
Is this something I should check with my dealer on? Can they verify and if
it is off will they reprogram? Again, thanks for everyones help!
Old 03-02-2005, 09:00 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Maybe the speedo is wrong.
Old 03-03-2005, 08:52 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Actually, all F-150s are 95 or 105. It looks like the read we had was already raised by someone. Quite honestly, I've lived in Atlanta for 25 years I've yet to have a "need" to go faster than 95 mph.... just a "want" every now and then until I realized 5 minutes less time at home is better than being dead!
80ford100
12-21-2014 12:44 AM
ninegeorge
Bio-diesel, Propane & Alternative Diesel Engine Fuels
06-28-2014 12:23 PM
Rasputin53
05-21-2014 02:35 PM
catdaddyyy
04-14-2014 05:02 PM
GAMIKE
New Member Introductions
11-12-2013 03:54 PM
Quick Reply: How to remove top speed limiter
