freeze plugs
Can I suggest a test for the block heater before removal.......
First make sure the BH red power plug is in the BH, then do a continuity test with a meter on the main plug wires at the grill. If there is no continuity check the wires for breaks just behind the 120V plug at the grill. If it's broken wire(s) then just cut the end off and replace the 3 prong plug, if the 2 power wires do have continuity through the BH.
PLC7.3
PLC7.3
stevelacey75
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
11-12-2004 08:29 PM
millbobs
03-30-2001 06:26 PM
