Partitioning my hard drive
Partition Magic (7.0?) is a nice software that will partition your hard drive without installing everything again. Your PC will have two partitions with Windows XP on the partition you choose.
Just checked, Partition Magic is now owned by Symantec http://sea.symantec.com/content/product.cfm?productid=1
You could get a free soft to do this, but be very careful. You could lose all data.
Also think that this could be very stressing to your hard disk. All data has to be relocated.
EDIT:
Forgot to mention that you could find also a boot software to choose between Win XP or linux. It would be nice to make a partition disappear to the non-operating OS so each OS won't screw with each other.
EDIT:
Yes, but a 4gb is a little small for a usefull linux install... Most places now sell hard drives pretty cheap, and they are very easy to put in... I'd go buy a new one (at least 20gb) and install your linux on it... If you aren't happy with SUSE try Mandrake, or Red Hat's Fedora Core. I use both, and am using FC pretty much all the time now.
Check with the Linux forums for help with this like:
http://www.reallylinux.com/docs/consult.shtml
You can make bootable partitions with Partition Magic.
Unless you know a lot about PC's, both hardware and operating systems you may want to rethink your Linux plans.
with the linux setup you should be able to devide the drive but last time i did it was years ago when i was playing with linux and that is how i did it but i think you have to go though code to do it the only time i deal wiht linux now is when i fix my tivo bc tivo is linux based eather when i upgrade a drive or a drive fails me and to restore the image back or when hacking it
I've used PartitionMagic 8.0 to create a Linux partition with great success. I've also used fdisk but can be difficult to use depending on your comfort/skill level.
Fedora Core comes with the GRUB bootloader that will allow you to dual boot your machine. I'm not sure if SUSE comes with a bootloader, however.
Good luck and always back up your data before doing any type of partitioning. Have fun!
What I do when installing various operating systems or just a Window's based one is to have two drives. One for the O/S and one for all the data. Some Window's programs do make it difficult to relocate data files to anything other then the default C: drive. There are ways around it.
This way to easily back up just your data all you have to do is copy or .zip all your data to a CD. To burn a CD (vs. file copy) of data goes much faster and easier with a separate HD.
If your O/S crashes and you have to reformat or reinstall the O/S, just unplug the slave drive, do what you have to the master drive, then once all set, just replug your slave drive in. Your data stays intact and the O/S will automatically recognise the new drive at reboot.
Woogs, repartition the drive using partition magic 8.0. Resize the windows partition to not less than 3 gigs using partition magic, and if you use windows as the primary os you'll need a larger windows partition. When you install Suse, it will see the partition space available and you select that partition for Suse.
success! . . . almost
thank yall for all the help. after a few hours of trying this evening I succesfully got my hard drive partitioned and both Windows and Linux running. but now I have no idea how to get back on the network (I'm on my dads machine)
my dad builds/maintains networks for a living and can help me with windows, but he knows nothing of Linux. what information should I ask him about our network to give yall enough information to help me get on there with linux? all I know is it's DSL, and wireless. ohh and we have a server (domain or something?)
thanks
woogs
EDIT: I did it by re-installing windows and partitioning the hard drive then.
then just booted linux from the CD and installed it on one of the partitions
thanks
woogs
