Temp Range For E4OD
Old 02-09-2005, 03:01 PM
Gene W's Avatar
Gene W
Gene W is offline
Temp Range For E4OD
I am going to add a transmission temp gauge to my van with E4OD transmission. The gauges are available with various tempruture ranges, ie, 100-250 deg, 140 -280 deg, 140-320 deg and so on.
The gauge with the 100-250 deg range suits my needs otherwise if this range covers the range of the transmission.
Can anyone tell me what the normal operating temp range is for this transmission including towing duty?
Thanks,
Gene
Old 02-09-2005, 07:58 PM
mike93's Avatar
mike93
mike93 is offline
100-250 temp gauge should be just fine. keep your temps between 160 and 200 deg. F on the dial.
Old 02-10-2005, 12:28 AM
Fordbronco69's Avatar
Fordbronco69
Fordbronco69 is offline
Infidel
What about a C6? I do alot of bobcat towing in the summer and i put an extra 2 qt pan+plus a trans cooler for a 32,000 lb vehicle on there to keep things nice and cool when under heavy loads.
Old 02-10-2005, 09:26 AM
Gene W's Avatar
Gene W
Gene W is offline
Thanks for the reply Mike.
Gene
Old 02-10-2005, 07:19 PM
mike93's Avatar
mike93
mike93 is offline
Your welcome! Keep it cool!
Fordbronco69
Same thing. keep it between 160-200 deg F. with that kind of cooling on your C6 it'll last for ever.
chrislynn5
05-01-2016 07:04 PM
matt12
13
03-12-2013 03:00 AM
johaner78
09-12-2011 08:31 PM
chrison600
04-29-2011 04:10 PM
Marine5811
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-17-2010 07:20 PM
Quick Reply: Temp Range For E4OD
