4.6 triton miss HELP (AT WITS END)
Have 2002, F-150, 4.6 triton. Ran great, parked on Friday, started on Sunday morning had very bad miss. Check engine light came on, (Was very cold that weekend) Took to garage, they showed a miss on #8, installed new spark plugs, cleaned injectors, checked fuel pump pressure, and replaced #8 ignition coil. Ran good until the next morning, and now miss is back. **As engine warms up, miss is not so bad, but still there, only under load or aceleration. If I stop for 15 minutes and then come back and run the truck, THE MISS IS GONE! But if the motor cools down, the miss will come back until it warms up. Took it back to the garage and the computer reads everything is normal. But it will still miss upon startup until it warms up and is shut off for a peroid of time. Does this sound like a "choke" problem? P. S. under slow aceleration on warm motor there is no miss.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
I was having a very similar problem with my 2001 F250 5.4 and a friend suggested putting a fuel system antifreeze and cleaner in the fuel. The problem cleared up with in 5 miles of driving. I am also going to change the fuel filter tomorrow.
I hope this helps you, Pete
I used Prestone Cold Start
DonKid
11-14-2012 07:51 AM
